How can I make a 3-D model of three letters on Onshape CAD
It needs to have a depth of 4 feet (which I have figured out how to do), a length (up and down) of 10 feet, and a width (side to side) of 15 feet, 45 feet total width if you include all of the letters. How can I do this. I am on a mobile browser FYI.
I would view this link on a laptop/desktop
You will most likely not get the exact dimensions you are looking for due to the scaling of the different fonts. In my recording, you will see I first try the width and then the length dimension as the driver to see how it is impacted. The main thing you need to get this done is the insert sketch letters option when you are editing a sketch, then dimension one of the edges and then extrude the letters to the desired depth.
Twitter: @bradleysauln
see help here - https://cad.onshape.com/help/index.htm#text-rectangle.htm?Highlight=text
