In a drawing: Assembly in one view, part in another
Hans_Ole_Leirvik
Member Posts: 84 PRO
Hi I am new to OS and can't find and solution to this.
I have an assembly of 3 parts.
On the first drawing sheet I show the assembly with the 3 standard views for dimension details, welding specifications and so on.
On the following 3 sheets I want to show the individual parts in the assembly for detail dimensions and so on.
Is there a way to select any of the parts-studios for a specific view on a sheet ?
You should be able to select the little cube on the left of the insert dialogue and get to the view selection navigator like this
5
5 -
Thank you
Perfect !0
