Simple flat bottom hole?
adam_richardsonadam_richardson Member Posts: 35 ✭✭
Am I missing something obvious? I'm a newbie to Onshape, so could be... Using the Hole tool, it appears I can only make blind holes (ie not going all the way through) that have conical ends (as though drilled with a bit). Is there really not a way to make a simple flat bottom hole? Have looked through the documentation and not seen a way to do it, other than manually drawing the holes in a sketch and doing a remove-extrude.
    edited November 2017
    You're right. I couldn't find an option within the Hole feature for a flat bottom or 180deg drill. However, you can get around that by using Delete Face on the conical surface and capping it flat.
    If you'd care to raise an improvement request I'll vote for it.
    HWM-Water Ltd
  • adam_richardsonadam_richardson Member Posts: 35 ✭✭
    Done, thanks Owen
    Cheers, vote cast, OwS
    HWM-Water Ltd
