Keep the dialog mate dialog box opens in assembly
sergio_p_sergio_p_ Member Posts: 37 ✭✭
Hi,
It wolud be an improvement of the interface if the dialog box for adding mates would keep open in order to allow to make new mates without having to open again. The same while we apply constrains, maybe a better procedure would be to add some dialog box to select the kind of constrain, and then choose the elements to apply. In this way we don't need to select every time the same option.
Regards
Sergio PLUCHINSKY
CAD, FEA and Engineering Consultor
+54 9 11 2250 0564
  • pete_yodispete_yodis OS Professional, Mentor Posts: 666 ✭✭✭
    @Sergio_P_ Ticket #2196 covers this, if it helps.  Maybe you can be added to it.
  • jakeramsleyjakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 668 image
    If you submit the mate by pressing SHIFT + Enter, then we will submit the mate and bring up a new mate of the same type.
    Jake Ramsley
