Extruding Multiple Faces of a Single Object
craig_fish
craig_fish Member Posts: 3 ✭
Hello,
How would you go about making a cube with a different pattern recessed into each face?
I've made the initial face and extruded it symmetrically for a total distance of 30mm. I did symmetric because this particular pattern I want to show on the two opposing faces. My pattern is extruded symmetrically to 28mm.
I then created a new plane offset 15mm to the right and did a new sketch for this face of the cube. However, I cannot "extrude" my new pattern into the face of the cube here.
Any advice?
  • craig_fish
    This is what I've got thus far.
    I guess I didn't realize I could sketch on an extruded surface.  :o
    https://cad.onshape.com/documents/c7a9b0960f4c65c0fa62dba1/w/0b2cc9abcd28237e1f8bce7c/e/bcafbd2aca82f465228f54e6
  • craig_fish
    Owen,
    Your "remove" comment led me in the right direction. I wasn't selecting that in the tab at the top. Rookie mistake from a rookie.
    Thanks!
  • owen_sparks
    Sure thing, glad you got it working  :)
    Owen S
    HWM-Water Ltd
