Divide by units or use parentheses...
CAD_SSPCAD_SSP Member Posts: 45 ✭✭
edited December 2017 in Using Onshape
To convert a measurement to a number in a formula you divide by the units, i.e. 22mm/mm = 22
If you want to do something like 220mm/22mm you get an error so you have to do 220mm/22/mm = 10
Also possible (and much more readable in my opinion) is 220mm/(22mm) = 10.
I would like to know if there is any reason to use the former over the latter, either performance or gotcha's.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    I agree that parentheses is more readable and is totally good to use.  But read below if you want to get technical.
    There are no performance gotchas here -- it's the same (negligible compared to other calculations Onshape is doing, unless you're in a tight loop in FeatureScript, in which case that's a separate discussion).  The only thing is that the floating point roundoff may be different between the two expressions; that roundoff error is thousands of times smaller than the size of an atom, but if you do a non-tolerant check, like (220mm/22/mm == 220mm/(22mm)), it may evaluate to false (and in this case it does).
