Access to sketch elements
Andrew_74
Andrew_74 Member Posts: 4 ✭✭
I'm probably missing something, but it seems to be unnecessarily difficult to access newly created sketch elements.
I want to create a sketch containing two lines and then extrude one of the lines depending on other conditions.
The extrude requires a query as input, but I can't find a query that will return an element with a specific name from a sketch.
  • kevin_o_toole_1
    Every time you create a sketch entity, you give it a sketch id (a string like "line1") which can be used to track that entity. The query which gets a particular sketch entity is named sketchEntityQuery. Used for your case:
    annotation { "Feature Type Name" : "Extrude lines" }
    export const extrudeLines = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "Use other line" }
            definition.useOtherLine is boolean;
            var sketch1 = newSketch(context, id + "sketch1", {
                    "sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE)
            skLineSegment(sketch1, "line1", {
                    "start" : vector(0, 0) * inch,
                    "end" : vector(1, 1) * inch
            skLineSegment(sketch1, "line2", {
                    "start" : vector(-1, 0) * inch,
                    "end" : vector(0, 1) * inch
            skSolve(sketch1);
            // debug(context, sketchEntityQuery(id + "sketch1", EntityType.EDGE, "line1"));
            // debug(context, sketchEntityQuery(id + "sketch1", EntityType.EDGE, "line2"));
            opExtrude(context, id + "extrude1", {
                    "entities" : sketchEntityQuery(id + "sketch1", EntityType.EDGE, "line1"),
                    "direction" : vector(0, 0, 1),
                    "endBound" : BoundingType.BLIND,
                    "endDepth" : 1 * inch
    So the simple case is indeed simple.
    HOWEVER, in practice, this works well for sketch edges and points, but not for sketch regions. Regions, unlike edges, don't have convenient ids (imagine 3 rectangles creating up to 7 regions... how would you identify them?).
    So, I think most of the time, FS best practice is to use multiple sketches, so that a downstream feature (like extrude) can simply use a full sketch without worrying about the details.
