Placing mate connectors according to geometry grips
I'm still on Onshape learning curve. Practicing by creating a tubular frame. The image shows a view where two different tubes were mated to the face of tubes mitered together. I placed mate connectors according to the "grips" that appeared on geometry for tube ends and faces. What I've found is the tube mated at the miter is centered, but the other mated is off by a small amount. What's going on here? Thanks in advance.
  • john_harkness106
    john_harkness106 Member Posts: 2 ✭
    Crap, forgot image.
  • owen_sparks
    Hi, if you post a link to your doc I'm sure someone will jump in and let you know where the problem lies.
    HWM-Water Ltd
