Resolution
brian_pinder662
Member Posts: 119 ✭✭
in General
Can anyone help please. Must have pressed something wrong as all my tabs and everything has gon to half size.Been trying to get back to full size for an hour now but no luck.Probably something to do with resolution but don't know how to fix. I am using a Mac. any help would be appreciated.
Best regards Brian
Best regards Brian
Jake_Rosenfeld
Moderator, Onshape Employees, Developers Posts: 1,646
Hi @brian_pinder
It sounds like you accidentally zoomed out your browser. command -> plus will zoom in your browser, command -> minus will zoom out your browser and command -> 0 (zero) will return your browser to normal. Try holding down the command button and hitting the zero key, everything should go back to normal.Jake Rosenfeld - Modeling Team5
All best wishes for Christmas & the Near. Brian
