Codes?
albert_sebastianalbert_sebastian Member Posts: 2
Hi before i start,
amazing stuff! i love the work, i am just waiting for more features to come on.
Also i would like to know,
Do you intend to add any programming features? (maybe similar to openscad)
its mainly because today i had a problem. i wanted to design a sphere with a polygonal face all across.
now i developed a code to make something(still working on fixing the nodes in 3d). but if i am successful i will be able to get a sphere of my size, a polygon of n sides and s as length of each side and create an entire sphere just from these parameters.
If not, any explanation why onshape will not move into such a platform?
In the case if that was not part of your initial ideas. is it possible to be added to your suggestions. in the future.
Because i would love to create a few solids which can be used this way. its sometimes hard to model it one by one. for example the same case i would probably have to create a hollow sphere, cut out the polygon and then replicate it. which may or may not fit properly.
Also, would u guys be having any plan to add some STL correction also with onshape.
Thanks and Regards
Albert Sebastian
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    I can't say much more yet, but I think you'll be happy with what we're working on on this front.   :)
