Tangent Arc Query
kiarian_coohillkiarian_coohill Member Posts: 16 EDU
I'm on the 'Fundamentals 2: Sketching' tutorials, 05. Exercise: Intermediate Sketching.
Going step by step, as per the instruction, for the most efficient way of producing this sketch, I'm not having any joy with this part. I draw a line. I then select the 'tangent arc' command, click the tangent and the line, but my result is not the same as the tutorial, even though I've added the 'tangent' constraint. What am I missing?
    @kiarian_coohill
    The line which I've circled is meant to be an arc, I think.
    You should probably try redrawing it.
    IR for AS/NZS 1100
    Start the tangent arc from the line and end on the other arc.
  • bradley_saulnbradley_sauln Moderator, Onshape Employees, Developers Posts: 373 image
    If you are still seeing this after trying the suggestions above, try to continue with the example. Sometimes adding additional dimensions/constraints, later on, will still give you the correct final profile. Some of the images in the training are grabbed at the end of modeling the designs.
    You will notice that the training screenshot sketch is fully defined (the lines are all black) while your sketch seems to be undefined in some areas (blue lines). Perhaps you might have missed a dimension or constraint in previous steps?
    Twitter: @bradleysauln
  • kiarian_coohillkiarian_coohill Member Posts: 16 EDU
    @kiarian_coohill
    It is an arc. An arc with a very large radius. It's supposed to be a tangent arc though. That's what's confusing me.
    Read my comment above ^^
    I've redrawn it. Everything is fine, up until this same point in the exercise. See photos to illustrate what I mean.
    You have to manually add a tangent constraint at the other end. A tangent arc only adds tangency at the start.
    Ahh, I see. I selected the line, after doing the tangent arc, selected tangent constraint, then the line adjusted to suit. Thanks.
