opExtractSurface using derived feature
papawo
papawo Member, Developers Posts: 206 PRO
  • Jake_Rosenfeld
    Maybe try this?
    // Get all the faces from the derived feature
    const inputFaces = qEntityFilter(qCreatedBy(definition.profile), EntityType.FACE);
    // Get all one-sided edges of the input faces
    const oneSidedEdges = qEdgeTopology(qEdgeAdjacent(inputFaces, EntityType.EDGE), EdgeTopology.LAMINAR);
    // Get all the faces touching the one sided edges
    const externalFaces = qEdgeAdjacent(oneSidedEdges, EntityType.FACE);
    // use externalFaces as your "faces" input to opExtractSurface
  • papawo
    edited January 2018
    Thank you ! It works! can you further explain this code?
    but i must say qEdgeTopology should be qEdgeTopologyFilter
  • kevin_o_toole_1
    A different approach:
    Add a function at the bottom named qOuterSketchRegions:
    </code>export function qOuterSketchRegions(features is FeatureList) returns Query
        var query = [];
        return qUnion(query);
        for (var feature in features)
            query = append(query, qSketchRegion(feature.key, true)); // true to filter out inner loops
    </pre><div>(This function uses the standard&nbsp;<span><a href="https://cad.onshape.com/FsDoc/library.html#qSketchRegion-Id-boolean">qSketchRegion</a> function, which has a filterInnerLoops option)</span><br><br>Then change your definition of profileEntities to:<br><pre class="CodeBlock"><code>        const profileEntities = qOuterSketchRegions(definition.profile);
    Example document:
    https://cad.onshape.com/documents/14f1f8d4f2979c9f4e6ffacc/w/1e643421e968f502e2ecf590/e/32fceec70cdf2150e1c75386
