Marble machine tracks in Onshape
tarek_mustafa
Member Posts: 40 ✭✭
in General
Hi Onshape Forum,
I like to challenge myself with a new little project and thought about building a nice marble machine for my children and myself :-)
My question, Is it possible in Onshape to design this kind of curves rails (as per enclosed picture?)
I currently just see the option to draw rails that are "flat" since restricted to a sketch plane.
Please let me know if there is a way to realise this kind of "freeform" shape or would I need to use different applications for that kind of design.
Thank you,
Tarek
Thank you,
Tarek
_Ðave_
Member, Developers Posts: 712 ✭✭✭✭
This link to an Onshape thread "how to model a hose" looks to be useful for this application.
https://forum.onshape.com/discussion/comment/4812/#Comment_4812
Dave
5 -
jakeramsley
Member, Moderator, Onshape Employees, Developers, csevp Posts: 668
Yup, you will most likely have to use surfaces to split a part/parts in order to create a path to then sweep along. Try looking at the path from the top to get a rough idea of how a thin part should look for that, sketch that, extrude all the way up. Then look at what the path looks like on the right, sketch that and use that as a surface to split the part. This should give you edges that are usable for a sweep path.Jake RamsleyDirector of Quality Engineering & Release Manager onshape.com5
Dave
