Curved line to sheet material?
jan_peter_tamminga
Member Posts: 2 ✭
I designed a simple curved shape that I want to saw from a sheet of MDF. How can I get the dimensions of the curved shape so that I can draw it manually onto the MDF and saw it out with my jigsaw?
Jan - you could print the drawing (or just a dxf/dwg) at 1:1 scale and attach that to the MDF. Just follow the lines with your jigsaw.Philip Thomas - Onshape1
Or if the sheet is too large add a bunch of points to your sketch along the curve, use the dimension tool to get x/y coordinates, transfer those to the MDF and finally join the dots by hand.
Owen S.
HWM-Water Ltd1 -
For an approximate transfer you can use a projector and trace the image while projected to sheet.www.accuratepattern.com1
Owen S.
HWM-Water Ltd1 -
