Selecting solid lines rather than lines lines by default when the 2 are on top of eachother
silas_bennettsilas_bennett Member Posts: 2
I have a complicated pattern that I am trying to sketch out, and I have a few construction lines to make things easier, but whenever I need to select a solid line that is on top of a construction line I have to use <RightClick> ==> <Select Other> to select it.This is REALLY annoying. How do you tell Onshape to prefer to select the solid lines?
  • michael_mcclainmichael_mcclain Member Posts: 198 PRO
    Try using the button above tab. Typically a ~ symbol. It's a hotkey for select other. You can always check any keyboard shortcuts at the menu in the top right.
