<p>Welcome to the Onshape forum! Ask questions and join in the discussions about everything Onshape.</p></p><strong>First time visiting? Here are some places to start:</strong></p><ol style="list-style:inherit;margin-left:25px;"><li>Looking for a certain topic? Check out the <a href="https://forum.onshape.com/categories">categories filter</a> or use Search (upper right).</li><li>Need support? <a href="https://forum.onshape.com/post/question/community-support">Ask a question</a> to our <a href="https://forum.onshape.com/categories/community-support">Community Support</a> category.</li><li>Please submit support tickets for bugs but you can request improvements in the <a href="https://forum.onshape.com/categories/product-feedback">Product Feedback category</a>.</li><li>Be respectful, on topic and if you see a problem, Flag it.</li></ol><p>If you would like to contact our Community Manager personally, feel free to <a href="https://forum.onshape.com/profile/6/LouGallo">send a private message</a> or <a href="mailto:lgallo@onshape.com">an email</a>.
</p>
</p>
Making cookie cutters out of Text
edward_casati
Member Posts: 8 ✭
I'm having trouble with something that seems should be fairly simple.
I want to extrude text, but just the edge. Imagine making a "cookie cutter" where the "letter" is 100mm tall, but it is only an outline with 2mm thick walls, 5mm tall.
Suppose I type the number "1". I then extrude it 5mm. I end up with a 5mm thick "1". I then make a new "1", but this one is 94mm tall. Two things happen... If I overlay the numbers, they haven't scaled the same. And I can't "extrude/remove" to create an outline.
So how do I take a standard text character, convert it to an outline, thicken the outline to 2mm and then extrude the whole thing 5mm?
Try just using a shell operation after extruding the text sketch:
https://cad.onshape.com/documents/e10ca383dc67d02ffd0130b7/w/5879ea94e5d4e3871a744448/e/b90aabd0a82f0605fbb13803
5 -
Yup, or extrude the edges as a surface and then thicken.
Owen S.
HWM-Water Ltd5
5 -
Owen S.
HWM-Water Ltd5 -
Thank you! I knew there must be a simple answer.1
