Issu with opSplitPart
MikeSarrey
Member Posts: 2 ✭
Hello all !
I'm a new Onshape user and I'm trying to make my first script.
This script goal is to make a helical cam like this :
I made this part using Solidworks pretty easily using 3d parametric curve but it seems that there are no similar feature on Onshape. That's why I'm trying to write it by myself. Actually, I almost succeeded by genereting with the script the 2 curves, creating a surface between them and a ring. My problem is with the opSlipPart. I don't understand how it work. I want to split the ring with my wave surface and to keep the part from
https://cad.onshape.com/documents/6d44ab7129cbaa1042d4ab5a/w/a7f47da4d52d7aa4e1c1f1e5/e/14c0ced3d21998160c14140b
FYI, there is a parametric curve custom feature here: https://cad.onshape.com/documents/578ff8b3e4b0e65410fcfda3/v/ee58cb1db7f6bcf3edeb1122/e/cc0c3d5644a78b1b64d6c3b4Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
I think the problem in your code is with the targets query for opSplitPart: qCreatedBy(id + "Ring", EntityType.BODY) doesn't resolve to anything because a boolean doesn't create bodies, it modifies existing ones. qCreatedBy(id + "cylinder1", EntityType.BODY) should work better. In any case, you can use debug to see what a query evaluates to.Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0
Thank you very much for your answer ! It works well !0
there are a number of ways in OS to create such profile - Sketch wrapper FS for example allows a nice control abilities, as it uses 2d sketch curve that is mapped to the cylinder or cone face
https://cad.onshape.com/documents/fe622d67f34560a1c1e2a0ca/w/7a13fae6edb7aed2a88c4cf1/e/13d6aedaac72d5c14499c2a7
1
