Merging different versions in a new better way.
Actually when you merge one version into another, the merging version prevail in dimensions and the active workspace version prevail in features, causing sometimes errors in some features.
I'd like to propose that also features from the merging version prevail to the active workspace version features by SUPPRESSING ALL THE ONES THAT ARE IN ERRORS.
I think you could test this operative operative's way and, if acceptable, you could adopt it substituting the actual one or by giving to the designer the possibility to choose from this two differents merging ways.
The advantage in my new merging idea is that you probably won't have any error after the merge, errors that (you know) designers ate!!
