FeatureScript smooth edges
MBartlett21
Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
in FeatureScript, I would like to make my own error message instead of the one generated by opFillet();.
I have written this function to fillet all the edges in a model except the ones that are specified.
https://cad.onshape.com/documents/b7252b2d8824c81fa19efffe/w/62f20e91708c14f2b8e1330f/e/47f23a63404badcd4649270d
I would like it to say that there are no edges that it can fillet if all the edges are smooth
If I were to do this I would use evEdgeConvexity. Here's some psuedo-code (I skip passing contexts and other such stuff). Assuming you are doing
opFillet(edgeQuery)
I would do something like this:nonSmooth = false<br>edges = evaluateQuery(edgeQuery)<br>for each edge in edges:<br> if evEdgeConvexity(edge) != SMOOTH:<br> nonSmooth = true<br>if nonSmooth:<br> opFillet(edgeQuery)<br>else:<br> throw regenError("All edges are smooth")
Paul Chastell
TVP, Onshape Labs5 -
@paul_chastell
I have redone the feature.annotation { "Feature Type Name" : "Fillet Everything" } export const filletEverything = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Fillet radius" } isLength(definition.filletRadius, BLEND_BOUNDS); annotation { "Name" : "Don't Fillet", "Filter" : EntityType.EDGE || EntityType.FACE } definition.noFillet is Query; } { //This is the edges that will be filleted const edgesToFillet = qSubtraction( qSubtraction( qBodyType( qEverything( EntityType.EDGE ), BodyType.SOLID ), qEntityFilter( definition.noFillet, EntityType.EDGE ) ), qEdgeAdjacent( qEntityFilter( definition.noFillet, EntityType.FACE ), EntityType.EDGE ) ); //This boolean tells the feature whether the edges are smooth or not var smooth is boolean = true; var edges = evaluateQuery( context, edgesToFillet ); //This for loop detects whether edges are smooth for (var edge in edges) { //This detects whether the selected edge is smooth or not if (evEdgeConvexity( context, { "edge" : edge }) != EdgeConvexityType.SMOOTH) { smooth = false; break; } } if (!smooth) { opFillet( context, id + "fillet1", { "entities" : edgesToFillet, "radius" : definition.filletRadius } ); } else { throw regenError("There are no sharp edges that can be filleted."); } });
1 -
Nice.Paul Chastell
TVP, Onshape Labs5
opFillet(edgeQuery)
Paul Chastell
@paul_chastell
Here is what I was doing:opFillet(context, id + "fillet1", { "entities" : qSubtraction( qSubtraction( qBodyType( qEverything( EntityType.EDGE ), BodyType.SOLID ), qEntityFilter( definition.noFillet, EntityType.EDGE ) ), qEdgeAdjacent( qEntityFilter( definition.noFillet, EntityType.FACE ), EntityType.EDGE ) ), "radius" : definition.filletRadius });definition.noFillet is the faces and edges not to fillet.
@paul_chastell
1 -
Nice.Paul Chastell
TVP, Onshape Labs5
