Feature UI: Input grouping
lemon1324
Member, Developers Posts: 230 EDU
Would it be possible to add the ability to group feature UI elements visually? The Laser Joint UI has a lot of options which then conditionally display further options, and it would be nice if these were clearly associated for the user.
So in this example, either indenting, shading, or a combination of both. Suggested syntax would be something like
I'll raise it as an improvement request if it makes sense; I'm not sure if anyone other than me needs this functionality.
annotation { "Name" : "Allowance", "UIHint" : ["DISPLAY_INDENTED", "REMEMBER_PREVIOUS_VALUE"] }
isLength(definition.allowanceVal, FIT_OFFSET_LENGTH_BOUNDS);Ideally this would be a small enough indent that DISPLAY_SHORT can also be used on the same line, if possible.I'll raise it as an improvement request if it makes sense; I'm not sure if anyone other than me needs this functionality.
Arul Suresh
@lemon1324
I'd also like to have a scroll bar on the side of the feature dialogues for when I am using a smaller screen.0 -
Hi,
This type of stuff is possible, but please make/vote for an improvement request -- it's how we track interest and prioritize. Thanks!Ilya Baran \ VP, Architecture and FeatureScript \ Onshape Inc0 -
Added IR for voting on here: https://forum.onshape.com/discussion/8418/feature-ui-input-grouping/p1Arul Suresh
PhD, Mechanical Engineering, Stanford University0
