Cannot assign to constant value through lambda.
brad_phelan
Member Posts: 91 ✭✭
Attempt to do a standard functional programming trick
but I get that I cannot assign to "const" value. Is there any way to write generators in featurescript? I also tried.
to the same error. Have also tried arrays instead of maps. Nothing work to inject some state into the lambda.
function incrementer() { const counter = new box(0); return function() { counter[] += 1; return counter[]; }; }function generator(value is number) { var valueBox = new box(value); return function() { valueBox[] += 1; return valueBox[]; }; }https://cad.onshape.com/documents/e39bbc03ade7ea27cba2656f/w/52a2f86fe05dfd95d6c5963b/e/23f61f89801e865ffacfaf55
https://cad.onshape.com/FsDoc/variables.html (see 'Box')
