3D Connextion space mouse
wayne_sauder
Member, csevp Posts: 634 PRO
in General
I have a wireless space mouse, just got it and it worked fine for a couple of days. Now it only has zoom function in Onshape, it works fine in their trainer. I've tried all the suggestions on the forums uninstall, reinstall, turn off firewall, etc. Nothing changes.
When I look for the page https://127.51.68.120:8181/version
It fails, gives an (err_connection_refused) Message
Is this a problem on 3D connexions side or Onshape, or on my computer?
I have two machines and the ability to run on different internet connections, I've tried all the combinations I can think of makes no difference.
Interested in any ideas you might have!
1
Sorry to hear you're having this trouble. With the connection error on the version check page, it sounds like the problem is on the 3D Connexion side. Please contact them and see if they have any advice.
It is a 3DConnexion Driver Issue. Works sometimes on some computers but, if you dare to switch the computer off overnight, chances are that it will not work next day.
I have 4 x Win10 Laptops running Onshape, Solidworks, and Fusion360 as follows:
Dell M4800 Workstation
Dell M4500 Workstation
Dell Inspiron 1520
Lenovo Ideapad 700
I have 2 x 3DConnexion Mice for Laptops, one wired Space Navigator for Laptops, one Space Mouse Wireless.
All computers are fully up to date with latest drivers and Win10 updates. I use the latest version of Chrome.
Problem is that the 3DConnexion mice do not work with Onshape or Solidworks with the 3 Dell Laptops (all I get is jerky zoom in and out). The3DConnexion trainer and Fusion360 work fine.
Funny thing is that both mice work fine on all 3 Programs (Onshape, Solidworks, and Fusion360) when I use the Lenovo Ideapad 700, so I am forced to use my ultra-portable Lenovo laptop in order to use the benefits of 3DConnexion mice.
I tried going back in time with 3DConnexion drivers, but with no success.
My IT expert is of the opinion that there is a problem with the 3DConnexion drivers.
3DConnexion Support is totally non-existent in Australia. All they are interested in is sales. I cannot log into my 3DConnexion account or forum to report the issue to 3Connexion, because the login process is broken. I reported the broken login issue to the suggested email link in the 3DConnexion website, but have had absolutely no response.
Please help. I have a very angry wife.
1. Close Chrome
2. Stop the 3Dconnexion driver
3. Start the driver
4. Open 3Dconnexion Cube demo
5. Start Chrome and Onshape
in fact my real problem is with CATIA v5 where SE works for first few seconds and stops. Then I do above steps to get SE working in CATIA. :-)
I was forced to make repair installation of my Windows 10 system because of failures with network an wifi card. After Fresh install with keeping apps and setting the SpaceExplorer works without need to use Onshape tricks. It is enough to stop and start driver. :-)
3DConnexion released Version 10.5.5 on 22Feb2018.
I replaced Version 10.5.4 with Version 10.5.5 on my 2 Dell workstations and, lo and behold, all works as intended on Onshape, Solidworks and Fusion360.
It remains to be seen if 3DConnexion remains stable. Please excuse my scepticism. Once bitten, twice shy!!
BTW I now have a second system and am seeing the same problem on both. Older one is a Surface Book, the new one is an brand new HP Z2 Mini workstation, so a completely different system, drivers, graphics card etc. Both running latest version of Windows 10 (1709). I followed up a few days ago with 3Dconnexion from the ticket I originally filed a couple months ago, haven't heard back yet.
The latest version worked great for 2 days, and this morning after switch on, just like before the 3DConnexion mouse will not work with Onshape on my 2 Dell Workstations. Back to the age old jerky zoom in and out regardless of selected motion. Works fine with Solidworks and Fusion360.
I tried the boot without the mouse connected, then connect the mouse after everything settles, but no joy. This trick used to work a couple of months ago, but deteriorated to not working at all.
Still works fine on my Lenovo Ideapad with the previous version. I am very reluctant to install the latest version on the Lenovo in case it stuffs it as well. So back to using Onshape on the Lenovo. Sigh!!!
- Find and execute "3dxnlserver.exe". (It was in C:\Program Files (x86)\3Dconnexion\3DxWare\3DxNLServer\bin on my computer)
- If Onshape is open, reload the page
- Once the page is loaded, click on the graphics area to make sure the tab has focus.
The 3dconnexion driver should be starting this service automatically, but it may be failing for some reason. If the service is running, you should see version information if you go to https://127.51.68.120:8181/version:You requested /version<br>Server version: 1.2.3.145191. In the morning, boot the computer with the USB 3DConnexion Mouse connected and wait for everything to settle (5 minutes).
2. From desktop, run "3DConnexion Home"
3. From 3DConnexion Home, run "Viewer". This software is terrible, because it appears to hang with the spinning circle of death. However, once you get sick of waiting, click on the Top RH corner "X" in an attempt to close the window. Lo and behold, the test model loads (instead of closing the window). What Mickey Mouse software!! A 10 year old kid could write better software.
4. Once the test model appears, use the 3DConnexion mouse to move the model around. This appears to jolt the 3DxNLServer into life.
5. Close both Viewer and 3DConnexion Home windows.
6. Open Onshape and the 3DConnexion mouse works as intended. Sometimes I have to move a model around using arrow keys first, then use the 3DConnexion mouse. Once you get it functioning, it will work all day.
7. Repeat Steps 1 to 6 next day.
I have persisted with investigating the issue of 3DXConnexion USB Mice (jerky Zoom) with Onshape when using my Dell Workstation Laptops. Interesting thing is that the problem does not exist on a low power Lenovo Ideapad.
I finally (after 3 months), have communication with 3DXConnexion Support in Germany. I am still working with them to fully resolve the issue.
In a nutshell, on the Dells, 3DXConnexion 3DXNIServer is not being initiated from 3DXConnexion 3DXService (a batch file in Startup). 3DXNIServer is the driver that is used to communicate to cloud computing applications such as Onshape.
Works fine on the lowly Lenovo. I am thinking there is a timing issue during the boot routine, where the Dells are too quick.
I am running the latest version of Chrome and 3DXConnexion (10.5.5).
As a temporary workaround, this daily routine (Steps 2 and 3 below) works:
1. Disable 3DxService in Task Manager Startup. (See Figure 1)
2. Boot the Dell Computer and wait until everything settles.3. From the Windows Icon in the bottom LH corner Type “3DxService”.
4. Select “Enable Driver”.
Figure 2 shows in Task Manager, 3DXNIServer is running and Onshape functions as expected.
Figure 3 shows 3DXService enabled in Task Manager Startup. This is the boot condition in my situation, that causes the jerky Zoom problem.
Figure 4 shows 3DXNIServer operation is missing if I boot with 3DXService enabled in Startup. This is the reason why 3DConnexion USB Mice do not work with Cloud based Onshape.
Figure 1. 3DxService Disabled in Startup
Figure 2. 3DXNIServer running after Driver Enabled
Figure 3. 3DxService Enabled
Figure 4. Task Manager Services if 3DxService enabled in Startup
And here I am, almost 7 years since last post to this topic, with the very same problem! As suggested, I noted that 3dxNlserver was not running, so I started it manually, refreshed my onshape page, and lo!, the Spacemouse is now recognised and controls my document.
