How do you select what parts do or don't get included in a view on a drawing?
Pascoe_Design
Member Posts: 18 PRO
in Drawings
I have a large 'master model' for an assembly and wish to create a set of drawings to show several different views. I would like to be able to create a drawing of the entire assembly and then de-select some items from the view, or choose which items to create a drawing of. This is akin to using Rhino or Autocad where you could select whether layers are shown or not in a viewport. I hope I am missing something obvious since this is really an essential feature!
Hope you can help,
Stuart
Hope you can help,
Stuart
philip_thomas
Member, Moderator, Onshape Employees, Developers Posts: 1,381
@Pascoe_Design - thank you for your question.
Yes you can do this today - the procedure is documented in this Tech Briefing that would will find in the Learning Center
https://learn.onshape.com/learn/article/branching-to-control-part-visibility
We will of course be streamlining this workflow as soon as possible.
Philip Thomas - Onshape5
