Using a surface with kerf to split a shape.
scott_hess
scott_hess Member Posts: 8 ✭✭
As a challenge, I was trying to model an "impossible dovetail" box for a 3d printer.  A bit I'm a little stuck on is how to slice the box into two parts with consideration of tolerance.  As far as I can tell, the sketch I'm using to split the box is a zero-thickness surface.  Based on past experience, I know I'll need a something like .1mm on either side of the cut to make for a reasonable interlock.
The best I can figure right now would be to build a shape and use that to split things, which will be ... annoying.  Certainly doable, but annoying.
Work in progress:
   https://cad.onshape.com/documents/d8640e8237336dfd1fceeefe
