Removing a section of a extruded tab
https://cad.onshape.com/documents/5248b23741bbb4ad0133e9ca/w/4db2a12bd146cc9851d6291c/e/0ff91e50b1f6d3429c59ba46
If you look at these tabs you might see that from the edge of the radius that they are cut back to a degree, but not all the way up the tab so as to leave a beveled top. This is so it can snap into place to there perspective slots. I'm trying to figure out how to cut a section of the tabs back from the edge of the radius.
2) start over with a revolved shape including the relief & bevel. Then do an extrude remove to take out material between tabs
