flat pattern in drawings
bryan_lagrange
Member, User Group Leader Posts: 942 ✭✭✭✭✭
I am going to log this for an improvement request.
I would like the ability to change the view of the flat
pattern in drawings. The flat patterns are currently defaulted to one view and
when you project views to flip it the bend lines do not show up or the call
outs. Depending on the material you are using (especially if you buy something
like pre-polished stainless steel) you need to have the bend directions in the
down orientation. It is a mix bag when calling in flats. Half default the way I
need them and the other half do not which I would need to change the view of
the flat but like stated above I get no bend lines or notes.
On another note I would like to have the ability to change
the angle call out. What Onshape defaults to I need the complimentary of that
angle because that is what my Trumpf press brake needs.
Thank you
Bryan Lagrange
