Selecting Multiple Dimensions
in General
Generally, selection is continuous- ie. each consecutive object I click is selected. However, this doesn't appear to be true of dimensions on a sketch. I have also tried holding down shift, ctrl, and alt to select multiple dimension with no success. Is it possible to select multiple dimension at the same time?
You can't select multiple dimensions in a sketch, except on mobile.
IR for AS/NZS 1100
