Export parametric relationships to text files
gregory_gundersengregory_gundersen Member Posts: 2
I would like to export the parametric relationships in an Onshape model to a text file. For example, if I had a simple model with a cuboid A and sphere B and a parametric constraint such that the width of A is the radius of B, I want that data in plain text: A and B have such and such coordinates and dimensions, and they share a single constraint. Is this possible?
    Short answer is yes
    Long answer is you would need to write a custom feature (featurescript) that would output these as text to the console
    Philip Thomas - Onshape
  • lucas_green366lucas_green366 Member Posts: 2
    I'm brand new to OnShape and I was wondering if there would be any pushback to me attempting to write a way to export an openscad file from OnShape, preserving variables and constraints if that is possible?
    I expect that a combination of FeatureScript, API calls and a browser extension might be able to pull it off, but I don't want to go down this road if it's an unwelcome idea.
