My school project - setting the depth for a cylinder
holly_bernon
Member Posts: 2 ✭
I am a first time user doing a project for school. I want to add a cylinder (for a piston) in to a solid block. I have added a circle and extruded it and it went through the hole block. Can someone tell me how I can set a specific depth. Thanks Holly
See this example: https://cad.onshape.com/documents/f0423ffab048638b9c335c45/w/2363dd0ed73a73bd8b86aeab/e/237ab74fbcfbfc996063ed55
You may also want to share your document when you post to the forum, this will make it easier for folks to help you out.0 -
In case you're trying to make a cylindrical hole instead of a protrusion, just select the Remove option. Setting the depth is the same as Paul' video.0
