Distance & centre of mass measurement
Hi
I am following the learning pathways regarding assemblies..
I follow all the steps mentioned (No changes in part sizes), and when i finally try to measure distance between 2 entities i get 151.755 mm (minimum distance)
Correct answer(parallel measurement) is supposed to be 151.673
Here is a link to my document
https://cad.onshape.com/documents/aacfdaa6e765e24100119452/w/e4ca840330c0f3c2d8979268/e/1f1be0ecf437adffe375b053
There also seems to be no way of choosing between minimum distance/ parallel distance etc.
What am i missing or doing wrong ?
Similarly in this excercise, i get a completely different value for Center of Mass compared to what is 'supposed' to be correct in the learning pathway
http://https//cad.onshape.com/documents/8ace740f14987e822997364f/w/b05c9d66e686ab6caab04338/e/07d4652d77dbdd9ee380dc05
    You must have fixed your model, because when I measure it comes out to the correct 151.673mm.
