Regarding animation
chand_bashachand_basha Member Posts: 66 EDU
hi,
    how two give animation for two different mates at a time (probably one revolute & one slider) and how to save that animation as a video. some one help me.
  • mahirmahir Member, Developers Posts: 1,321 ✭✭✭✭✭
    Look into mate relations. Specifically, if you want to relate rotation of one mate to linear motion of another mate, you would use a Screw Relation.
  • chand_bashachand_basha Member Posts: 66 EDU
    not that one sir, i want to see both revolute and sliding of the swash plate at a time.
    @chand_basha
    Could you share a link, please?
    IR for AS/NZS 1100
    I'll say it again. Animating a revolute and sliding mate at the same time requires the the Screw Relation unless you have other parts driving the separate motion. But if I recall correctly, your test assembly has the swash plate assembly modeled/mated in such a way that it would not rotate anyway. In the real world, rotating the upper drive ring won't rotate the swash plate. It will only move it up and down. I think maybe you should do a few assembly tutorials. Learn to walk before you run.
Howdy, Stranger!
