Diagonal dimensioning in drawings
Hello, I am a newbee to Onshape. I am liking what I am discovering. But I, would like to know if there is a way to insert a diagonal dimension in the drawings process? It keeps jumping from horizonal, to vertical. Am I missing some trick?
Thanks
  • brucebartlett
    edited March 2018
    I found it hard to get it to work recently when doing a drawing. Afer a few frustrating minutes, I found I had to drag up to the top right and it started working for me.  I had not experienced this problem before.
  • john_mcclary
    are you selecting the diagonal edge? or the two points of the diagonal?
  • terry_falldorf
    terry_falldorf Member Posts: 7 ✭
    John, Thankyou for the quick response. But I am trying to get diagnal from corner to corner of a rectangle to show the square of the rectangle. I think I'm going to have to draw a construction line from corner to corner and dimension that?
    THANKS AGAIN!
  • MBartlett21
    THANKS AGAIN!
    @terry_falldorf
    You won't have to do a construction line, just move your mouse up to the far top right or far top left.
    It will then go diagonal and you can move your mouse back in.
    IR for AS/NZS 1100
