Importing from Excel
I am really fascinated with how powerful OnShape is, I am still assessing it. On my work, I have a small matlab code that calculates parameters of a set of features and exports these parameters to an excel spreadsheet. I then read this excel file into my current CAD modelling system which automatically patterns the selected feature following the parameters in the excel sheet.
I was capable of building a small script inside OnShape that was capable of patterning the selected feature based on the parameters I input into the function successfully. The issue that for each feature I have 8 parameters. I usually have 75+ of these features. I can't input each parameter 1 by 1.
Does anyone have the same issue, is there any work around that would facilitate data entry to OnShape that can then be utilized to by the system?
TIA
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,252 image
    You can upload a CSV file from Excel into OnShape and use it in FeatureScript.  See https://cad.onshape.com/FsDoc/imports.html#importing-external-data and post (with a link to your document) if you run into issues -- we'll help!
    edited March 2018
    if your parameter calculations doesn't involve some complex math with integration or differentiation would be better to directly write it in featurescript. if native implementation is not possible the data can be copied and pasted into feature studio as some of the FS container type constants directly or imported and read from the file as Ilya said
  • mohammed_abdullatifmohammed_abdullatif Member Posts: 3
    that solves it.
    Thank you.
    Thanx, but on matlab I actually solve partial differential equations that govern the distribution of my features...more over, the code on matlab is huge, rebuilding it inside FS would be very inefficient.
    Thank you
    that sounds cool, good luck then.
