Handrail to Spiral Stair
Good Morning, Could anyone give a little advice please. I have have completed a spiral stair to the point of adding the handrail and now wish to add the handrail. (Now the fun starts) The stair has two intermediate landings and a top landing. Sweeping round a helix is something I have in mind at the moment but yet to try. The biggest problem will be connecting to the horizontal sections of the landings which will need some careful manipulation. Is there anyone who may have done this and can give a little help.
Regards Brian.
Regards Brian.
Something like this:
after a little experiment i found that in this particular case Sweep normal gives the same result as Variable section sweep, the result of builtin sweep is not suiting. The only problem with Sweep normal is that it fails when you give it multy edge wire body instead of a number of individual edges
https://cad.onshape.com/documents/affea6ffe4df420f453419a7/w/e82e20fbea3d518ffaa26ce3/e/b115b786f0a5c6d579561451
