Extruding with an offset on all 4 side
RyanAvery
RyanAvery Member Posts: 93 EDU
edited April 2018 in Community Support
I want to extrude the 5 drawers selected here, but I want a 1/8th inch gap on top, left, bottom, and right
So i dont want to extrude the squares I have selected, but rather the squares i have selected but each of them trimmed on all 4 sides by 1/8th inch.
Is there an easy / fast way to do this?
  • RyanAvery
    What about for extruding a set amount on all 4 sides of a box, the full depth of it.
    I.e. a tool / FS that can do this to any cube that I select after I select the face of it (so it knows to extrude the 4 faces connected to that face)
  • RyanAvery
    Is this something I should look into to writing a FS for? Or is that too much time? Would it be best to just stretch the boxes bigger with a copy, then boolean subtract the first from the copy?
  • Jake_Rosenfeld
    @RyanAvery
    If you want to try your hand at FeatureScript, this would be a pretty simple feature to write.  In moderate-pseudocode it breaks down to
    export const trimmedExtrude = defineFeature(function(context, id, definition)
        precondition
            annotation{...} // <- Filter should probably be EntityType.FACE && GeometryType.PLANE
            definition.profiles is Query;
            annotation{...}
            isLength(definition.depth, LENGTH_BOUNDS);
            annotation{...}
            isLength(definition.trim, LENGTH_BOUNDS);
            // Find the extrudeDirection
            const dir = evFaceTangentPlane(..., {"face" : qNthElement(definition.profiles, 0)}).normal;
            //  Extrude the profiles
            opExtrude(context, id + "extrude", {
                         "entities" : definition.profiles,
                         "direction" : dir,
                         "endDepth" : definition.depth,
            // Find the side faces
            const capEntities = qUnion([qCapEntity(id + "extrude", true, EntityType.FACE), qCapEntity(..., false, ...)]);
            const sideFaces = qSubtraction(qCreatedBy(id + "extrude", EntityType.FACE), capEntities);
            // Push the side faces in
            opOffsetFace(..., {
                        "moveFaces" : sideFaces,
                        "offsetDistance" : -definition.trim
