View selector
terje_bersetterje_berset Member Posts: 4 PRO
Hi there!
Is there a setting that disables that Onshape zooms out and rotates when you select a plane view?
I would like it to stay in current position, current zoom, and just rotate to the selected veiw.
Thanks
-T
    I hadn't realised it did that, but agree it's undesirable.
    It seems the arrows surrounding the view cube just give a rotate without the zoom.
    Often I'll just click on a face and hit the "N" key for view normal to.
    Owen S.
    HWM-Water Ltd
  • philip_thomasphilip_thomas Member, Moderator, Onshape Employees, Developers Posts: 1,381
    @terje_berset - Hello! :)
    While there isn't a view mode that mimics your desire exactly, you can define any custom view you want and easily return to the same orientation, zoom and location time after time.
    Philip Thomas - Onshape
