3d printed parts
robert_scott_jr_
Member Posts: 765 ✭✭✭
in General
Rather than putting out cash for the purchase of a 3d printer as well as supplies, learning to effectively use it as well as the real estate it would take up and maintaining printer, is there a reasonably priced service for the hobbyist? - Scotty
The answer (at least in the UK) is, yes sort of.
Many companies (often termed Print Bureaus) will happily exchange some printed parts for some of your money.
The pros are pretty much as you explained, and they'll tend to have expensive industrial hardware.
The cons are wait time and that they'll probably charge in the order of 10 times the material cost.
We started off subbing out, but have now brought most of it in-house.
Cheers,
Owen S.
HWM-Water Ltd
like https://appstore.onshape.com/apps/Manufacturing/FMPGS3MADAVYEWRR2A6XOMF6K4YPZ25L3P6PANA=/description
Partner de PTC - Onshape Averigua a quién conocemos en común
Is there a maker community in your area? You may be able to connect with other hobbyist near you to get printing. There are quite a few and I'm sure many would be interested in helping out.
Right now I am waiting (sitting at curb actually) for a Prusa MK3 kit ...now delayed till later May
https://www.3dhubs.com/
It's a sort of consortium of folks (or companies) that sell 3D printing services, with each entity operating independently of the others. It looks like you can submit a design and get back quotes to compare. I'm guessing that you can pick local 3D printing services, which might reduce turn around.
If, on the other hand, you intend to print a lot of different projects, use various different materials, and anticipate lots of custom changes or configurations then you might be better served with your own 3D printer. Decent learning curve but not overly difficult and the flexibility you achieve is unmatched.
You also do not need to break the bank to get really good quality prints. I have 2 of these
https://www.amazon.com/Anycubic-3D-171-Upgraded-PRINTER-Heated/dp/B074NZPHJ5/ref=sr_1_1?s=industrial&ie=UTF8&qid=1524790252&sr=1-1&keywords=anycubic+i3+mega
and this one as well
https://www.amazon.com/Creality-3D-Printing-300x300x400mm-Self-assembly/dp/B078V7MHWY/ref=sr_1_6?s=industrial&ie=UTF8&qid=1524790293&sr=1-6&keywords=cr-10s
I print more on the AnyCubic because the bed gets hot enough to print various materials but the CR-10 prints larger models and both are known for their great quality.
