Sketch Profile Location For Sweep Path?
larry_hawes
Member Posts: 478 PRO
I watched a few videos on OS's sweep feature and thought I saw it emphasized that the sketch profile for the shape of the sweep needed to be 'coincidental' or 'pierced' with the sweep path, even to the extent of creating a new plane point if needed, 'use' the point from the path and create the sweep profile on that new plane. As in this vid -
https://www.youtube.com/watch?v=A2eFC33J6nI
It seems that is not entirely true, or actually not true at all. A bit confused by this discovery and was wondering is this a new feature? Or was it always intended to work this way? And what is the upside/downside using either technique.
Thanks
http://www.youtube.com/watch?v=Q74-HJwQZKU
https://www.youtube.com/watch?v=A2eFC33J6nIIt seems that is not entirely true, or actually not true at all. A bit confused by this discovery and was wondering is this a new feature? Or was it always intended to work this way? And what is the upside/downside using either technique.
Thanks
http://www.youtube.com/watch?v=Q74-HJwQZKU0
emagdalenaC2i
Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
I'm not sure if it was added in an update, but not in the latest ones. You can see the change log here https://www.onshape.com/changelogThe best thing is that you don't need that the route and the profile were coincident and for example, you can create several sweeps with the same route, as in the second video in your post.The worst thing is that if the route and the profile are not coincident, it could be difficult to control the shape of the desired sweep
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común7 -
emagdalenaC2i
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común8
HWM-Water Ltd
