used a threadcreator now part crashes
Hannah_Scheu
Hannah_Scheu Member Posts: 3 PRO
Hi
I've used the ThreadCreator on a part and my part won't reload and says I should go to support with my support code 71def6fc9879c21c51064c11 if it won't go away.
Please help, thanks :smile:
  • bruce_williams
    Please post a link if possible.  See this checklist for how to post on the forum
    Also, You can use the Feedback tool under ? (help icon) to share the issue with support.
    www.accuratepattern.com
  • lana
    edited May 2018
    @Hannah_Scheu
    You should be able to restore the state before adding ThreadCreator from Versions And History page for this document.
    If you share your document with Onshape support and post a link here, I'll fix it for you
