Why is my sheet metal flat view reversed from my isometric view?
Help needed. Did I make a wrong setting somewhere??
@verne_severson
Could you please submit this via Feedback tool (In ? menu) to support and share your document.6 -
Right now there is no way to define the 'up' direction in sheet metal models. We pick an 'up' for you on body creation and all of the bend directions are relative to that. Like you pointed out, your model won't be built incorrectly, it is just isn't the direction you wanted.
We also only show the bend centerlines and bend notes on one side.
We know this is an issue and are looking to address it in the future.Support & QA6
@verne_severson
We know this is an issue and are looking to address it in the future.Support & QA6 -
You toolbox exercise shows Up direction. That is based on a sketch on the Front Plane. I have tried other new documents and it always picks Down - even if I try to duplicate your Took Box from scratch. When I sketch on the Front Plane the extrusion causes the flat view to use Down. I tried a sketch on the Right Plane and it made the flat view be up.
I found that I can affect making the flat view match the isometric view. The problem happens when using Extrusion to start a sheet metal project.
Solution: When viewing the sketch to make the Sheet Metal Model, it makes a difference on the order I select the edges to extrude:
Does Not Work: Select left, bottom, and right.
Does work: Select right, bottom, left.So I started the whole project over again, this time selecting the edging in the other order. Now the flat view matches the isometric view.
1
