Rolled sheet metal
Hello there, new project. Could anyone help. I would like to add some holes to a rolled sheet metal part but can't see how this can be done. Can anyone say if this is possible, if so a little advice would be appreciated.
Brian
Brian
You can add holes to a rolled piece of sheet metal but we'd like to clarify a few things first. Do you want the hole to be circular before or after it is rolled? Right now we can only help with creating holes that you want to be circular after the part is rolled resulting in a potential ovular shape in the flat pattern (we can't design in the flat pattern right now).
You can either sketch out your hole features as seen here:
Or use the hole feature as seen here:
You can find more general info around our sheet metal but looking at this section of our help documentation.
Twitter: @bradleysauln
Brian
I may be misunderstanding your question, but arbitrary planes can be defined using the "Plane" feature:
https://cad.onshape.com/help/Content/cplane.htm
You cannot sketch directly on a rolled surface, currently sketching can only be accomplished on construction planes (created by the "Plane" feature) or planar faces. You can either sketch a circle and then "Extrude" with "remove" option to cut the circle, or you can sketch a point and use the "Hole" feature.
https://cad.onshape.com/help/Content/extrude.htm
https://cad.onshape.com/help/Content/hole.htm
HWM-Water Ltd
Best regards tro all, Brian.
