No Export funtion on Onshape Moble
This is one seriously big missing feature from Onshape moble. Not only is the export fuction crucial to the workflow, allowing you to get files from any mobile device..but the export function is also used to move one assembly or part’s studio to another document. Not having this is a real bummer, adding this funtionality would greatly increase its power.
Also, any chance we can get a fully functioning 3D slicer for FMD matchines in the future?
Cheers
Cheers
If you would like to see this implemented in Onshape, please vote on the following improvement request:
https://forum.onshape.com/discussion/comment/32752#Comment_32752
Unless your goal is to have solids with no history, there is no reason to use export to move geometry between documents. Both the "Derived" feature in a part studio and the "Insert" feature in an assembly can get geometry from other documents and maintain full associativity.
https://cad.onshape.com/help/Content/derived.htm
https://cad.onshape.com/help/Content/insertpartorassembly.htm
