Mating a rafter to a beam
Hey - can anyone help me figure out how to mate a rafter to a beam? See my model of a timber frame shed in public section titled Timber Shed. https://cad.onshape.com/documents/31721dc79321c240bb67a5be/w/9ed70b6514e984ffdfdb1bd7/e/cfe7f5fbe7815964f5f502d4
Thanks much!
Thanks much!
https://cad.onshape.com/documents/210595a1397d78537e7cb314/w/314b9e1c82ae013b750f427e/e/afbd0701f6681e0dc9c96108
It was all in a single Part Studio with less that 50 features.
Partner de PTC - Onshape Averigua a quién conocemos en común
1. You can create a mate connector in the Part Studio 3, like this
2. Then you can create a mate with this mate connector and the midpoint of the central beam
And it is done!
Hello :
The post has a tenon and the beam above has a mortice for that tenon.
1 Does the tenon cut the mortice automatically or after executing a boolean command?
2 If the post is moved, will the mortice move in the beam above?
3 If I wished to dimension the beam and print a drawing, I'd put the post on another drawing layer to hide it. In that case the mortice remains visible. However, the post must remain in position otherwise the mortice disappears.
4 How would OnShape handle this task?
Regards : Hubert Wagner
I have similar questions, can someone provide answers for the above?
