semi cut in section view? possible ?
franco_otaola
Member Posts: 23 ✭
hello,
i was trying to make a view of inside a part but i wanted to make the intersection of two planes but i cant arrive to "keep" the section i want.
i turn around things with a remove extrusion but as always this type of things is good to know if is doable:
what i want in left and what i can obtain from the section view, also i would like to know if it is at least doable in a drawing that it would be even more important.....
thanks!
thanks!
emagdalenaC2i
Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
You can create a configuration with that 3/4 cut extrusion and insert a view of that configuration in the drawingUn saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común6
