find volume of an STL in Onshape?
When I import my optimized part from Generate (the file is STL) how do I find the volume of it in Onshape?
- Select the parts in the bottom left area
- Click in the bottom rigth button to see the mass properties
Un saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común1 -
@emagdalenaC2CemagdalenaC2C said:- Select the parts in the bottom left area
I think he mentioned it was STL.
So? What's the difference?
He was looking for the volume of a imported part, right?
I have just realize of the STL file is a mesh XD, sorryUn saludo,
@emagdalenaC2C
When you import STL, it does not import as a solid.
You can use features like konstantin_shiriazdanov has made to convert it to a solid. e.g. Polyhedron FS.0 -
Sorry, I realized after answering youUn saludo,
Partner de PTC - Onshape Averigua a quién conocemos en común0 -
Yup, volume works just fine on stl files.O.S.Business Systems and Configuration Controller
HWM-Water Ltd0 -
If the STL creates a fully enclosed volume, then volume works fine. Click the mesh in the Parts list and if the scales icon appears in the bottom right corner then it is a fully enclosed mesh.Senior Director, Technical Services, EMEA1
