creating and sharing product documentation in a tab
philippe_marin
Member Posts: 26 EDU
Hi,
working on open source projects, I would like to create and share with partners a technical documentation. In order to ease access and modification, I would like to do it in a dedicated "tab" in Onshape interface.
Would it be possible or not?
I remember I saw some text documents with links in some Onshape exercises or tutorials, is it possible to do the same as a standard user?
Thanks...
Philippe
Thanks...
Philippe
Jake_Rosenfeld
Moderator, Onshape Employees, Developers Posts: 1,646
@philippe_marin
The tabs you saw were likely PDF files. If you go into a document and Import a PDF (from the "+" in the bottom left corner), it will get it's own tab and be rendered in full quality.
Here is an example of a PDF in an Onshape document:
https://cad.onshape.com/documents/9a9b81d17d4b69e58ad9b0b0/v/c253688ad8add5efd222a709/e/3152191074466a8b45231663
Hope this helps!Jake Rosenfeld - Modeling Team5
Hope this helps!
https://appstore.onshape.com/apps/Utilities/DFE73AMQ42NPMVAEQBQVP56QGLCWJ4ALJUBEBLA=/description
Partner de PTC - Onshape Averigua a quién conocemos en común
@emagdalenaC2C I already tried to use Link Tab, it looks a good way to build onshape embeded documents collaboratively. But after subscribing to Link Tab, when I select "Add Application / Link Tab" I just got a blank tab. No input field as expected to define a link :-(
But now I just tried with Firefox instead of Chrome, --> I go a bit further, I can define the URL (I try a Google sheet for example). But I get a message "The following link was prevented from being displayed in this tab" and I need to open outside of Onshape...
It seems to be not so simple (?)
Philippe
There were this kind of issues some time ago, Maybe you just need to "reinstall" the app
