VisualCAMc June 11, 2018 update
joe_dunnejoe_dunne Onshape Employees, Developers, csevp Posts: 198 image
Enhancements
  • Part load now honors part configurations
  • Facing operation extracts the stock model silhouette boundary automatically if no curves are selected for machining
  • Added pick two points on part for calculation of depth in machining operations
  • Toolpath Settings dialog was added
  • etting the cylinder axis to be parallel to the machining Z axis default for Cylinder and Part Cylinder stock
  • Added notification after the part was reloaded
  • User settings for post processing has been added
  • Help button was added to the Preferences dialog
Bug Fixes
  • Part is not updated when reopening document without switching to VisualCAMc tab
  • Prevent reloading the part selected in VisualCAMc tab, after modifying another part in the Part Studio
  • Geometry is not updated after reopening a shared document that was modified by another user
  • Geometry is not automatically reloaded when a part studio that contains a multi-body part is modified
  • The Mop(s) are not flagged dirty to prompt the user to regenerate the toolpath when geometry is changed in Onshape
  • Selecting add tool tip to drill depth on a Deep Drill operation drills deeper than what is should when compared to standard drill
  • Restore client-side mops active regions after geometry was updated in the part geometry
  • Prevent reloading of the part if user just switches from one configuration to another in Onshape
  • Error when trying to save Work Zero operation
  • Updated versioning notification popup to the view that more consistent with Onshape
  • Selecting Set to Stock box in Work Zero dialog does not show options to specify Face and Position when stock is defined using Cylinder or Part Cylinder stock
VisualCAMc App Store
Previous Updates
Joe Dunne / Onshape, Inc.
