Use of sketches in assembly, and mates in sketches...
john_P37
Posts: 27 PRO
Anyone know how to use sketches in an assembly? I've looked in the documentation and it seems you can do this, but I can't find the details. What I want to do is not complicated: In particular, I have a sketch of some straight lines laid out, and I want to attach parts, via mates, to the end or midpoints of the lines. It looks like if I have a sketch alone, I can't tie a mate to it: The mate connector is looking for an owner part, and since this is just a sketch there is no part to be the owner.
thanks,
John
thanks,
John
You currently can't place a mate connector in a Part Studio with a sketch as the owner part. If this functionality would be useful to you, please vote on this improvement request!
In the meantime, you can add mate connectors to sketches in the assembly, no owner part required. If you want to mate parts to your sketches, that's the workflow I'd recommend.
6
6 -
How can one create a sketch in an assembly?In the meantime, you can add mate connectors to sketches in the assembly, no owner part required.
@larry_hawes
Kevin is just saying that if you make a sketch in a Part Studio and bring it into an assembly, you can add the mates once the sketch is in the assembly.Jake Rosenfeld - Modeling Team0 -
Thanks Kevin, Jake - that will come in handy.Jake_Rosenfeld said:@larry_hawes
Kevin is just saying that if you make a sketch in a Part Studio and bring it into an assembly, you can add the mates once the sketch is in the assembly.0
