Multiple Sheet Formats in one drawing set
wesley_astin
Member Posts: 7 ✭
I have several drawing templates set up that have different title blocks (varying amounts of detail). is there any way to have different drawing formats (title blocks) on each sheet of a single drawing set? So sheet one would have all tolerance detail, title, description, dates, scale, etc. But the other sheets would less information in the actual title block. I cant find where you can change the sheet format from sheet to sheet. it's almost like whatever template you go with, it has to be used on each sheet.
You definitely can set your template up with the second sheet being different to the first. The second sheet will also be the template for all subsequent sheets. I have never done one of these templates with via exporting dwt from Onshape, so can't guarantee this would work, but remember creating one with dwg editor that worked as you described when loaded to Onshape.0
I was just updating one of my templates and it looks like you can do multiple pages straight out of Onshape now.
1 -
It sort of works, but the text in my title block is not placed the right place
how to fix that?
