Is There a Method to Loft/Extrude to a Single Edge?
larry_hawes
Member Posts: 478 PRO
in Drawings
Not sure how to tile this thread but am messing with some lofting and would love to get rid of the top sketch in this model and shape to a single upper edge. Is it possible?
http://www.youtube.com/watch?v=eDmnj-vPWvU
https://cad.onshape.com/documents/1b9f374eeae443ea0110f1b9/w/ead32ba4e2f11d0b9a2f432f/e/9572ebf3ae6ab59f88b75e2a
http://www.youtube.com/watch?v=eDmnj-vPWvUhttps://cad.onshape.com/documents/1b9f374eeae443ea0110f1b9/w/ead32ba4e2f11d0b9a2f432f/e/9572ebf3ae6ab59f88b75e2a
I suggest you use a single vertex at the top in place of the sketch you wish to eliminate, and guides to get the profile you want.
Owen S.
HWM-Water Ltd
WITH THE VERTEX COINCIDENT WITH THE GUIDES IT ALL MOVES PERFECTLY - caps sorry
As an extra thought you can set up the guides as splines then if you click the final button in the guide sketch you can move the drag handles on the splines and see the effect on the final part in real time. 😀
O.S.
HWM-Water Ltd
HWM-Water Ltd
